29er frame, carbon fork, alfine 8, powertap
touch
Post by touch »
Gary Fisher paragon 29er large frame. £80 + postage
Alfine 8 hub on stans ztr flow 29er rim. No bolts or anti-turn washers. Also lost the plastic locknut which holds the shifter on the hub. £80 + postage
Powertap sl+ ant+ hub on H plus SON rim. 10speed campag freehub. no skewer. £250 + postage
29er carbon forks. 490mm a2c 163mm steerer - very short headtube frames only!!! £40 + postage
touch
Re: 29er frame, carbon fork, alfine 8, powertap
Post by touch »
Frame is size 19". Cranks + seatpost not included.
There's a few scratches on it with one deep chip/scratch halfway along the top tube:
samcallard
Post by samcallard »
Hi,
Is the Alfine 29er wheel still available?
Thanks!
Whats the spacing for hub on the forks... I'll probably take them regardless olease.
