So last week I was walking (sorry ) the cornish coast path and bivi-ing. On both the nights I wild camped I found a decent spot (flat, water source, place for a swim in the sea etc.) but walked on past it for various reasons. First night it was because it was a tad early and the second was because there were a few people around on romantic sunset walks etc. Both nights I ended up in far less amenable locations usually only a half hour max further on.
So - for the non-racers - how do you go about choosing a spot to stop?
Don't need to be by water, just carry an extra collapsible container and you can bivi anywhere. In fact, water sources in the summer can attract flies, mozzies etc.
Nice views are great but my last few bivi spots have been picked when it's been dark. I don't hang around either in the morning, pack away my stuff and off I go (ride for an hour or so and then stop for breakfast once the sun has risen and warmed up)
Much depends on conditions / time of year. In winter I'll look for somewhere with natural shelter, in summer somewhere more open with a breeze. I will sometimes have a potential spot in mind, it won't be anywhere I've visited before, simply something I've seen on the map and thought it had potential.
I do sometimes think that if there's the likelihood of people, you're better being blatant and hiding in plain sight.
Silly Q sorry. How do you decide by lookin on map that somewhere has potential?? I'm planning to wild camp in the Peaks this winter during the Rapha500 you see so could do with the extra tips...
redefined_cycles wrote:Silly Q sorry. How do you decide by lookin on map that somewhere has potential?? I'm planning to wild camp in the Peaks this winter during the Rapha500 you see so could do with the extra tips...
Ta
For a winter bivvy spot I tend to have a rough distance in mind (at least 2/3 into the ride) then look on a map for a wooded area away from houses. Usually works.
I'm with Ben. In the Chilterns, the first place that ticks most of the boxes will be where I stop.
- just a dull roar from the nearest motorway
- <10 mins from the gastro pub where reservations have been made
- 4G signal and/or wifi access
- trees to shield you from the bridleway so the morning horsey folk and Barbour-clad dog walkers don't get all bothered
The map will tell you if there's a flat bit, how close you are to farms, buildings, footpaths etc. It will tell you whether there's likely to be any natural shelter and how near water is. It will give you a reasonable indication of what the ground conditions are (boggy etc). In fact, the map should largely tell you most things you'll need to know - it's not always right but more often than not, it'll produce some good results.
