Radnor Ring
Re: Radnor Ring
Can't open as in can't download, or an error in a mapping program? The following should work:
Right click the link and "Save link as...", then open it up in Tracklogs, Bikehike, Route Buddy or any other mapping program that supports GPX format.
Re: Radnor Ring
When I open it, it's a page of garbled text. It worked using bikehike.
I’ve been abart a bit
Re: Radnor Ring
You get used to it..., I don't even see the code. All I see is...bend, climb, descent...*sillybigfella wrote:When I open it, it's a page of garbled text.
* adapted quote from a movie
GPX is just an XML markup language I think.
Copy into Notepad and save with a GPX file suffix and it'll work.
- gairym
Re: Radnor Ring
took me a second but i got there.....Ian wrote:You get used to it..., I don't even see the code. All I see is...bend, climb, descent...*
