back to news and reviews
Posted by
A tent that you blow up and you can wear, really? Well, kind of. The Zelter Shelter is certainly wearable and you do blow it up but it’s probably best to think of it in terms of ‘shelter’ rather than ‘tent’. If you compare it to a very spacious hooped bivvy then you’ll be on the right track. In truth the ‘wearability’ factor isn’t likely to be a big draw for anyone reading this. However, the promise of a quick and easy to erect, fully enclosed and free-standing waterproof / breathable shelter, probably will be.
I suppose the key element of the shelter is the internal air chambers which once inflated provide both the legs and backbone. The inflation valve is located near the apex on a short flexible tube. There’s no pump required, just good old lung power. If you were in a rush, I’d estimate that you could have it out of the bag and ready to move into, in less than three minutes, so don’t imagine you’ll be huffing and puffing for hours.
This is the air valve. It really doesn’t take much to blow it up.
Once inflated, the shelter is free standing although there are some pegging points which will obviously prevent it blowing away across the moors in the middle of the night and will also help keep everything where it should be. There’s a surprising amount of room inside – don’t misunderstand me, you won’t be hosting any parties but it’s as roomy as many one-man tents and far more spacious than any bivvy, hooped or otherwise.
Certainly roomier than any bivvy bag you’ve ever slept in.
The door is zipped down one side and across the bottom, the zips are ‘waterproof’ and they’re also double ended so can be opened / closed from either top or bottom allowing you to leave a portion of the door open should you want to increase ventilation.
Two way zippers allow some additional ventilation.
Speaking of ventilation, in shelter mode, what would be the hood when worn, forms an additional zippered side vent / window so you can check to see whether it’s still raining without bothering to get up.
Is it a hood or is it a vent? It’s both.
Generally, it feels robust rather than svelte but the pack-size is reasonable (roughly 20cm x 30cm but could be compressed further) and at 1400g the weight isn’t excessive. There is a version that’s a shelter only and forego’s the garment side so I’d imagine it would possibly weigh a little less – I shall find out how much less for next time and let you know.
Waterproof roll-top bag and handy reminders in case you forget what you’re doing.
Something else you can also do with it is use it as a more traditional tarp. I’ll admit to not having tried that yet but I will give it a go over the next couple of weeks. I wouldn’t imagine that you’d buy it specifically to use as a tarp but it’s another string to its bow and any additional versatility can’t hurt.
Free-standing – no pegs were harmed in the taking of this photograph.
Anyway, I’m going to go and do some testing and I’ll report back very soon but if you want to know any more in the meantime, there’s lots of info over at the Zelter shelter website.
0 Comments
Leave a Reply
You may also be interested in
Read Full Article
Inclusive – at what cost?
Read Full Article
Read Full Article
Shopping cart0
Continue shopping
