Squeal like a fox boy.
Mike's already told this story but I promised I'd write something, so here it is.
The 'Toughest Push In Wales' or CLInt Hill as it's also been called, had led to a later than anticipated arrival at Penhros Isaf. In turn, that had resulted in a later than usual departure the following morning, which meant the food provided by the cafe was more late lunch than early breakfast. By the time each of us had taken our turn to say, "we'll just have one last brew", whatever light there was, had begun to disappear.
Something was wrong, my legs wouldn't work. They hadn't been overly compliant the previous day but I'd shrugged it off and assumed day two would see them return to their usual form - I was wrong. Insignificant inclines became monstrous hills and I found myself twiddling along in 22 / 32, while trying hard to formulate convincing excuses for Mike and Scott. My only hope was that tomorrow would be better.
Although gravel had given way to tarmac, the change in surface didn't herald the arrival of civilisation. The road pushed us deeper and deeper into the mountains but in doing so took us nearer to our destination. The map indicated a bridge, a left turn, a track and if luck was with us, somewhere to spend the night out of the incessant wind and rain. The deafening roar of water indicated that we'd crossed the ancient stone bridge and in accordance with the map, we found the start of a puddled, muddy track leading off into the blackness. In less than five minutes we would find out whether my hunch had been correct. If it was, then salvation and a haven for the night beckoned but if I was wrong, well, let's just say the evening could become very unpleasant, very quickly. We pedalled on, each of us secretly wishing, hoping and praying.
A kink in the track delivered us from evil. Lights picked out the dark silhouette of a structure just off to the right - we weren't home and dry but hopefully, we were home. The final tussocks of the day deposited us safely by the front door. I turned the broken remnants of the handle, nothing. I was unwilling to believe it was locked, so tried again with a little more force - bollocks. Mike was already making his way round the side looking for a chink in the building's armour - I stood staring at the locked door. I looked down at the floor hoping to see a piece of slate lent against the wall or a stone that looked out of place, anything that might indicate the location of a key. No stones and no slate, I lifted my head and looked up. Hammered into the door frame was a rusty screw, hanging from it was an even rustier strip of metal. For no real reason, I reached up and lifted the metal from the screw and beneath the bent strip of oxidising steel was a key. I walked inside and straight over to the window Mike was trying to get through. "How did you get in there?", "magic" I replied.
Inside was spacious, dry and just a little dusty. A brush was located and in full accordance with the 'leave no trace' ethos we set to. Five minutes later and you'd never have known the place had received any form of cleaning in the previous ten years. With our bedroom now sorted, we retired back down the wooden stairs to partake in the age old bikepacking ritual of eating, brewing up and talking rubbish. It was a friendly building, it almost felt lonely. Perched high out in the mountains waiting for the warmth and noise of human company, a reminder of its previous life. As we sat, sprawled out along the battered wooden benches, the building slowly drew the heat out of us. At first it was just our feet but the old stone and slates were hungry and within a couple of hours we were all starting to experience the tell tale shivers that indicate bed-time. We ascended the stairs once again and reacquainted ourselves with sleeping bags and mats.
I wanted to sleep but the more I wished for a speedy journey to the land of nod, the more unlikely it became. I lay there listening to Mike and Scott as they contended for first prize in the 'Worlds Noisiest Mat' competition. Scott's Neoair sounding very much like the often mentioned crisp packet and Mike's Exped producing a more worrying sound, a sound like someone rubbing a half inflated balloon between their arse cheeks. With the collar of my jacket stuffed firmly in my ears, I rolled onto my side and stared out of the low window that faced me and thought. I thought about my legs and whether a new day would see them rejuvenated. I wondered whether the rumbling noises from my stomach meant I was hungry or full. I tried to work out how I'd not seen Mike blow up a balloon while I'd been in the same room and I thought about the lights outside the window. I gave the glass an extra hard stare hoping that it might scare the approaching lights away but they just got brighter. I told myself there couldn't be lights, after all we were up a dead-end track in the middle of nowhere at midnight, why would there be lights? Unfortunately, the only answer I could muster was that, the lights and more importantly, whoever was in charge of them must be coming here.
I decided not to invoke panic until the moment I actually heard a car drew-up outside and its engine stop and its doors open, I quietly said, "there's someone here". Mike had obviously decided that a certain level of panic was called for in this instance and replied, "you're f*cking jokin'" but soon realised I wasn't as the beam of a torch rushed through the window and lit the entire room up. We waited for the noise of a door catch but it didn't come, we thought about all the things we'd left down stairs in plain view through the windows and regretted all the money we'd ever spent on high-viz this and reflective that. We could hear faint voices but couldn't make out any words, lights continued to flash across the building and through the windows but still no one came in. BANG, Scott had remained largely quiet until that point, "f**k me, is that a gun?" he said trying to be as quiet as you can be in such circumstances. I let out an imaginary sigh of relief, they weren't here for us, they were here for the foxes. Minutes turned to treacle and passed like hours but eventually the car was started once more and the lights faded.
Okay, close your eyes and go to sleep, I told myself but out on the hillside a second shot kept my eyes wide open. For another hour, I watched the lamps light up the sky in the distance. The noise of an engine was never out of ear shot but sadly it wasn't loud enough to drown out the sound of rustling crisp packets and someone rubbing a half inflated balloon between their arse cheeks.
Re: Squeal like a fox boy.
A superb piece, Stu. Well worth the wait. :-bd
In even more suspense now. When's part 2? Who was it, were they after foxes and if so, why were they looking in the house? Was it the farmer? Whodunit?
darbeze
Post by darbeze »
If I had had the "balloon between my arse cheeks", I am pretty sure the gunshot would have either burst it, or I would have self lubricated it!!
Sounds a decent adventure to me...
Si
Mike
Post by Mike »
nice one stu
Wotsits
Post by Wotsits »
I always thought butt lube was obligatory when meeting up with others off the internet for nights in the forest... A generous application would certainly help quieten any mat-cheek interface :wink:
Sounds like a good trip & great write up :-bd
Scattamah
Post by Scattamah »
slarge wrote:In even more suspense now...were they after foxes...
There was one rather large/dead fox sleeping by the side of the trail not more than 20 feet from the side of Shotgun House. We joked about making a Davey Crockett hat. I don't think the fox thought it as funny as we did.
After the gunshot and subsequent torches shone in a fashion reminiscent of a wartime movie prisoner hunt, I had visions of waking up to no bike and having to walk out of Snowdonia. One tends not to sleep well with such thoughts on their mind. Luckily for me I had damp gear to wear and a storm to ride in to keep me wide awake the next day.
Good story Stu...sorry about the crisp packet rustling.
I wonder what they were looking in the hut for. They could presumably see stuff in there
I don't think they were actually looking inside. They'd have been scanning the hills looking for the foxes but the lights are so bright it felt like they were shining them directly inside.
It's quite amusing, you could have scared the life out of them, but maybe not when they've got guns
At least there were 3 of you, less fun on your own!
Mike
Post by Mike »
Jase, just for the record i was sleeping naked it was way to cold. I think it was the friction between the mat and the thermal blanket i borrowed off stu :-bd
That and me shivering to keep warm
Sorry Steve, you'll have to buy the book :wink:
Scattamah
Post by Scattamah »
I'll be buying the book exclusively for your graphic description of the bridleway, wall climb, chewed up forest track, log pile scamper and Clint Hill :)
Not that it's indelibly etched into my mind or anything like that *grins*
