Seam Sealer ... thin down or not?
As title really ... what's the general opinion when applying seam sealer on silnylon, straight out of the bottle or thin it down a bit?
Ta
Taylor
Re: Seam Sealer ... thin down or not?
Post by Taylor »
No idea.(ever so helpful)
Where do you get a "bottle" from?
I've only seen the little tubes from tent repair kits.
Anthony
Post by Anthony »
The Siltarp had a sewn loop in it's centre that dripped in bad rain. I just rubbed a little bathroom sealant into the threads with my finger :D
Not a good idea over a larger amount, it worked but it's not pretty!
I seem to remember you thin it with white-spirit but I guess it depends on what the instructions say?
Don't thin it down, apply neatly as a thin layer with a small brush (supplied?)
pedalhead
Post by pedalhead »
Good timing as my new MLD bivy bag came with a couple of tubes of Seam Grip that I'm going to be applying soon. From what I can tell, as Ian has said, undiluted and using a small brush is the way forward.
It's a fairly mind-numbing task, and probably took me a good 45 minutes to do my z-packs tarp.
pedalhead
Post by pedalhead »
yep one chap on BPL said it took him 5 hours to do his Soul bivy! That's something to "look forward to"...
I can do mind numbing ... I even quite like pointing.
Taylor
Post by Taylor »
s8tannorm wrote:I can do mind numbing ... I even quite like pointing.
I might have a job for you then because I bloody hate it.
pedalhead
Post by pedalhead »
Started doing my bivy bag last night. I'm in the "it's bloody boring" camp! :roll: Having said that, I have no idea how it took some bloke 5 hours to do his. Mine should be done in around 2. A small brush and a bit of patience seems to be working ok.
