I've read the review on here
Thinking about a light but more bulky load, is it possible to lock them on/use a cable tie to stop them bouncing off the forks?
Monkii
Re: Monkii
Get the monkii cage V, there's no way you'd ever bounce that off
Re: Monkii
I was looking at the Gorilla cage. ...
Re: Monkii
The Gorilla can be mounted 3 ways.I was looking at the Gorilla cage. ...
1/ Use all 3 mounts as per Anything cage ... won't come off as it uses the V type fastening.
2/ Use the top 2 mounts ... these are just a straight slide on mount.
3/ Use the bottom 2 mounts ... these use the V type fastening.
Re: Monkii
Shame they don't make a "3" Monkii Clip
