Bivvy spots on Mary Townley Loop.
Artie Fufkin
Post by Artie Fufkin »
I know this one was done a while back.
Am doing this ride next weekend, starting and finishing at Hebdon Bridge. Is there anywhere good to find a decent bivvy spot about half way?
Also if anyone has a gpx of the route that would be excellent.
Thanks in advance,
Chew
Re: Bivvy spots on Mary Townley Loop.
Post by Chew »
Any specific reason to start from Hebden?
Half way around from there would leave you around Rawtenstall/Bacup which wont make the best place to stop overnight.
You're never that far away from populaton so its probably worth playing it by ear.
Its a while since i've ridden it, but you should find some good spots around Watergrove Res, (Littleborough/Whitworth), Past Holme Chappel (stop at the pub then just keep going up)
GPX link
http://www.cycle-route.com/routes/Mary_ ... e-750.html
Artie Fufkin
Cheers for the reply Chew,
Starting at Hebdon as it's easy to get to by train from Leeds.
Will have a look at the map, and thanks for the gpx link.
