Tubeless lesson learnt.
Whilst doing the Cairngorms loop I picked up a puncture/slit in the side wall of a tubeless tyre that wouldn't seal so without thinking I just bunged in a tube which saw me good for the rest of the trip. Today however, whilst cleaning out all the solidified sealant on the inside of the tyre I came across a thorn which should have punctured the inner tube but didn't. I'm thinking there was still enough liquid sealant between the tyre and tube to seal it even though I had got rid of as much of the sealant as I could when putting the tube in. Lesson learnt, check your tubeless tyre for thorns etc before putting a tube in. I was lucky and got away with it.
Re: Tubeless lesson learnt.
Continental inner tubes with removable valve cores, Park Tool patches and a small Stans as back up.
I love tubeless but concerns on a long ride if it failed. ..
Apart from the thorns above what extra risk over tubes?jBay wrote:Continental inner tubes with removable valve cores, Park Tool patches and a small Stans as back up.
More I feel I need to take a spare tube when tubeless.
I always did when tubed, rather not fiddle with patches mid ride. Anything that slashes a sidewall would take out the tube I'd have thought. The downside to tubeless is if you want to frequently try different tyres.jBay wrote:More I feel I need to take a spare tube when tubeless.
Suture material. I've seen some long and big cuts. A suture and inner tube should have fixed the issue.
- mountainbaker
I always carry spare tubes. And when I was running Schwalbe tyres, I had to use a tube on every ride. Total crap. My Conti XKings haven't been touched by the local flinty mud mix though, but I always want to be able to ride home, so carry tubes anyway.
