Bio Ethanol
Bio Ethanol
Went to by some Meths today but the usual stores in town have switched over to selling Bio Ethanol.
Is it as good, or some i try and track down some of the old stuff?
Re: Bio Ethanol
I tried it Chew and took it back to go outdoors. Didnt burn anything like meths. The meths from there was about £2.
Re: Bio Ethanol
I shall have stocks of meths at the start of the WRT if anyone doesn't have any / forgets to bring some.
Re: Bio Ethanol
I've been using bio ethanol for ages, no issues, burns a bit more violently than normal method but cooks just as quick, it was something like a fiver for 2l so I would definitely buy it again
Re: Bio Ethanol
Stu - I'll probably need some meths - my usual shop is only selling the bio stuff ATM and I don't think I'll have time to run around looking elsewhere
Did I read somewhere that you are do your 8g stoves on special at the WRT - if you are I'll have one please
Re: Bio Ethanol
Are you doing the bigger ones on special too? Consider this registering interest.
Re: Bio Ethanol
That's right Steve, a special WRT deal ... all 8g and 22g stoves £15.Did I read somewhere that you are do your 8g stoves on special at the WRT - if you are I'll have one please
I'll also have poles, UL guy-lines, fuel bottles, the rare 0.3mm windshield material (some 0.2mm too) and MYOG cosy kits.
Re: Bio Ethanol
Can I register intersest in a 22g stove please :D
Re: Bio Ethanol
I'll have an 8g stove - just got the meths sorted.
Re: Bio Ethanol
just a thought - are you going to have a 140/145mm pole for my mini peak? - would like to compare one with my MSR one before I commit though!
Re: Bio Ethanol
No, that'd be a special Steve ... obviously it'll look the same as what's there only longer, so it'll give you some idea.are you going to have a 140/145mm pole for my mini peak?
Re: Bio Ethanol
that'll be great - just want to get an idea on how much lighter it'll be
