Getting under a low slung tarp
I'm 6'3, getting into anything small or under anything low isn't easy
I've never worked out a great way to get under a low tarp, particularly when it's wet, without getting wet from the ground or touching the tarp
Most of my tarp use has been with walking poles, i'll be using the bike (hopefully) to support the tarp so it'll be lower than with poles.
What are your techniques and tips for getting under tarps pitched low? (Prob applies to low/tight tents)
Re: Getting under a low slung tarp
Standing at a mighty 5'7" I don't have quite the same issues but I do find that setting the tarp up in a half pyramid form gives much easier access than an A frame (obviosly it depends gow big your tarp is). You might find coverage isn't as good but if you're selective with your pitch it's surprising what you can get away with.
Ben98
Post by Ben98 »
Stop
Drop
Roll
Best method I've found :P
Yorlin
Post by Yorlin »
Set up the tarp from the inside? :geek:
I'll be using a SilTarp1 on the WRT, was planning to use an A frame or lean to pitch
Side step press up, or rather press down
Doesn't that me you get mucky hands?
Likewise kneeling down you get mucky knees
When its bone dry and clearly it's ok!
benp1 wrote:Doesn't that me you get mucky hands?
:lol:
I tend not to worry so much about mucky hands
That does make me sound like a big girl, but I never have anything appropriate to wipe my hands on!
:grin:
Whatever you have on your legs. or the cuffs of your socks.
There's always the option of some type of small groundsheet. Doesn't need to be exotic, just a bit of plastic sheet will do but it'll give you something to sit / kneel on.
Bet you're a 'curtains' man Dave :wink:
s8tannorm wrote:There's always the option of some type of small groundsheet. Doesn't need to be exotic, just a bit of plastic sheet will do but it'll give you something to sit / kneel on.
how rude...
benp1 wrote:That does make me sound like a big girl, but I never have anything appropriate to wipe my hands on!
:grin:
You could just use the bloody great ruffle on the front of that blouse you're wearing?
:wink:
I'm already sorted mate, I'm packing an apron :lol:
I hope there's some Marigolds too :wink: :lol:
