Saw this on the TN website. Looks interesting but not available at the moment...
http://www.terra-nova.co.uk/tarps-bivis ... bag-cover/
New Terra Nova Moonlite
Re: New Terra Nova Moonlite
That looks like just what I'm after :D
I wonder whether they've made this new version any bigger? I always thought they were a bit snug.
£100 seems expensive compared to something from the US but given that this is taped and the rrp might not actually reflect the price you pay, it could be a good choice ... just hope it's a bit roomier.
It dosnt seem so.s8tannorm wrote:I wonder whether they've made this new version any bigger? I always thought they were a bit snug.
I have a moonlight and a disco light. both are very small.
I also wonder if they have made it waterproof. At least 2 of us on here have discovered the moonlight to be not so waterproof
I'd be looking to use it as a minimalist bag in summer for quick overnights with predictable conditions. As Stu suggests, i'd expect that in a couple of months it will be available for £60-£80 which makes it a viable option.
@FLV - were you not tempted to send it back?
You Tube:
Dan_K wrote:I'd be looking to use it as a minimalist bag in summer for quick overnights with predictable conditions. As Stu suggests, i'd expect that in a couple of months it will be available for £60-£80 which makes it a viable option.
Couldn't find a receipt for it, got it on the cheap from field and trek who wouldnt take a return.
Its fine if there's no rain and stays dry from moist mist / dew. but not good enough for proper rain. I'll likely still use it in the more summery months as it weights bugger all.
I borrowed marks one and found it was ok in beading but soaked water from underneath. This is problematic as its sized to not fit a mat in.
My guess is that if it had a properly waterproof base it would be much better. It would still need to be kept clean and regularly reproofsed to keep it beading well.
Extrem-textil probably sell the fabric if any MYOG folk fancy trying it out...
Personally I wouldn't buy one. If you're going to use a tarp there are lighter, similar (and lighter, better!) bivys and if you're not using a tarp then you need something that is actually water proof.
I think that's what I meant Ian.
Just that you said it rather better!!
