I've just come back from a little run using my new Garmin 'Forerunner 310XT' and I'm a little concerned about some of the stats.
Below you can see the numbers from the run (well, more of an aggressive saunter):
What's getting me is that after a gentle 3 mile jog it would appear that I almost died!
Here's some info to help you in analysing this data:
- Cold and icy/snowy (and was snowing).
- I was tired after a hard few days of little sleep and lots of travelling.
- At altitude (1000m arrived back in Alps last night after a week in London).
At no point was I particularly out of breath (no panting or wheezing).
I didn't feel like it was particularly hard work.
Other factors:
- The resting heart rate used (52bpm) in this calculation was recorded after getting up but I was up and about for a bit before taking it and so, if anything, it's an estimate on the higher end of things.
- The max heart rate (179bpm) was calculated using an online calulator (said to the most accurate without doing it properly) and so is liable to be in the general region (220 - age = 172) but I can't imagine any of the variances that are likely would explain me seemingly suffering so much on this run.
So.....is that something somewhere is terribly wrong (with my calculations or with my kit) and does this just show that I'm in incredibly poor shape???
(and if so why can I run that far without feeling that it's much of an effort?)
Any all help, advice and explanations appreciated.
Cheers, Gairy.
