XT chainsets?????
Taylor
XT chainsets?????
Post by Taylor »
Whats the difference between an M780 and a M782?
I can see they've got different size bolt circles. What does that mean?
M782 has lower gearing/less teeth.
Confused.com
Re: XT chainsets?????
flatfishy wrote:Whats the difference between an M780 and a M782?
Confused.com
I think you've answered your own question there.
Bolt Circil Diameter = the bolt pattern http://en.wikipedia.org/wiki/Wheel_sizing#Bolt_circle
The 'only' difference is related to the ring sizes. The 30t middle ring on the 782 requires the use of a different spider / bcd, hence the 96mm spacing rather than the more usual 110mm / 64mm.
If you think the 22/30/40 will be better for you than the 24/32/42 buy the 782 ... if not then just buy the cheapest.
Taylor
Post by Taylor »
Ta muchly
s8tannorm wrote: the more usual 110mm / 64mm.
104 for MTB innit? :?
104 for MTB innit?
Yes Zippy you're right, I should have typed 104 ... I've obviously spent far too long looking at cx rings ;)
