Son to sinewave wiring tips
Mr conners
Post by Mr conners »
I've treated myself to a new dynamo and lights but before I blunder into soldering etc c. Does anyone have a neat solution for push fit connectors that enable removing the lights without using those awful spade connectors.
I've trawled through a few forms but I thought it might be easier to ask the experts on here.
Re: Son to sinewave wiring tips
I bought these and then just used the actual.connections (.not the plugs ) which can be crimped on to your wire and then covered with shrink wrap. They just push toether and give a tight connection. One worked loose* when pushed together after about 2 years but a gentle bend of it made it firm again. cheap and easy solution avoiding soldering.
https://ebay.us/m/zZ5aON
* for the rear light never from the dynamo to front light. Dont thousands of miles over 5 years ir more with this and its a cheap solution
Mr conners
Cheers.
Looks like an elegant solution.
Taylor
Post by Taylor »
Dyna-snap
boxelder
Post by boxelder »
https://www.sjscycles.co.uk/dynamos/son ... connector/
These make connecting/disconnecting from Son hubs a breeze. SJS will make up a wire loom or whatever for you if not confident with coaxial soldering.
Like this, but with the sinewave connections you need:
https://www.sjscycles.co.uk/dynamos/son ... ness-21cm/
Mr conners
Looks really neat. I've bought a few decent bullet connectors off eBay and some silicone covered wire. I'll try to get myself something soldered up first and if it looks awful I'll go down the road of buying something already made up.
Sajama
Post by Sajama »
I use XT30 plugs small and reliable,just needs some shrink tube to insulate soldered cable.
https://www.aliexpress.com/item/1005002 ... 0batteries.
Mr conners
Thanks for all the tips. I went for the bullet connectors as I have to be able to switch the rear light connections over if I want it to flash or stay on, so I can't use a connector that only plugs in one way. All seems to work. We're riding to the dales from Whaley bridge on Friday night then back home on Saturday night just to get some night riding miles in so it'll be a good test.
