Clear out continues....
I have an alfine 11 hub built on a crest 29er. It's not done many miles <300 I'd guess. The rim is ok bar a couple of small knocks, it has a minor wobble but still holds a tubeless tyre no problem. It will come with the cable guide and all the fitting bits that came off that end of the cable. Obviously can provide photos on request. £350
Versa drop bar shifters in good working order. Some minor scuffs to the hoods, cosmetic issue only they work fine. £100
As per other advert I'm in Sheffield but will post at cost or can meet at the BB200.
Also FS: alfine 11 on crest 29er, versa drop bar levers
Re: Also FS: alfine 11 on crest 29er, versa drop bar levers
Wheel is sold now. Still have the shifters if any one is interested
