Thro axle mods
Sajama
Thro axle mods
Post by Sajama »
Adapted axles to fit racks with bolt thro axle points. Ortieb do a cheap 12 mm rear one and the Roberts axles are quite expensive.15mm front M4 drilled and tapped one side and an M5 inset bonded on the other. As it was quite easy made the rear 12 mm one as well.
