650b wheeset query
BridlewayBimbler
650b wheeset query
Post by BridlewayBimbler »
Hello,
I am.looking at 650b wheelsets. I note.that most state compatibility with 10/11/12 speed cassetes
My bike currently has a 9 speed Sora cassete fitted
Will I just need suitable spacers to make this work?
Re: 650b wheeset query
Free wheels have not changed my pro 2 hope hub has had casettes from 9 to 12 on it.
Road and mtb casettes (not sure about 9.speed.though) are different widths though road are 2 mm ish wider so not sure in this case.
Yes. Road 11-12s freehubs are a little wider than MTB 9-10-11s freehubs. If you have a Road 11-12s compatible freehub you can use any trad spline MTB or road cassette, a 9-10-11s MTB or a 9-10s road cassette just needs a 1.85mm spacer behind it to take up the space.
(edit - that 1.85mm spec is for Shimano freehubs, other brands might be different but basically same principle)
