Someone asked Bear Bones stoves work ... *thought this might explain things.
http://vimeo.com/71106578
*I'm really, really sorry
EDIT: Following a couple of messages I realise I should have held up one last bit of paper with 'available here' on.
http://www.bearbonesbikepacking.co.uk/p ... ntact.html
Entertained and bored in equal measure.
- 99percentchimp
Re: Entertained and bored in equal measure.
great choice of tunes :D
Conquistador of the pointless
Glad you approve Mark. I was going to go with Mr Cash but I figured my video production was a little more 'punk rock' so Social Distortion seemed more in keepinggreat choice of tunes
Are there no ends to this man's talents?
Me likey. I have never seen a meths stove in action before. This may convince me to make the change from gas.
What is the shield made from?
vaguely exciting film 8-)
Shields are any thin aluminium. The exact spec depends on your level of "resourcefulness".
As CM says, any aluminium sheet will work, as will foil. The shields I make are made from 0.3mm sheet ... I find that they hold their shape well even after heating, don't burn (thinner foil shields often do) and they have a good level of 'springyness' so can be rolled up and slid inside pots, etc.What is the shield made from?
I bow to the stove-guru that is Stu regarding the efficacy of various ally. Personally I just scrounge whatever is to hand and use it until it "dies" (at my rate of trips they might outlast me :evil:). Latest donor is one of those big disposal serving platters.
Pikey, but in a good way 8-)
Personally I just scrounge whatever is to hand and use it until it "dies" (at my rate of trips they might outlast me ). Latest donor is one of those big disposal serving platters.
Exactlydon't burn (thinner foil shields often do)
