Wtd: xtr rear mech/shifter 11spd
Anyone got any of the above bits. Something nice to go on Butcher (the bike). Not wanting to spend too much but interested to see what bling is out there please..
Last edited by redefined_cycles on Thu Jan 28, 2021 1:24 pm, edited 2 times in total.
Re: Wtd: carbon riser bars, drivetrain, pedals, 2.6 wide tires x 29er, cranks...
What cranks do you need? Boost or not boost?
I have not boost, SLX and XT. I'll do some photo's
I will take the XT please as long as they don't look worn. The hubs are orange so hopefully go with the frame color. Might as well get everything looking a bit blingety bling... I reckon I shoild be able to collect this week some time Dave (as there's shifts down your ends)...
Looking forward to the pics/prices... let me know how much for either please Dave
NB. Actually can you give us the price including postage please Dave. I'll take the better looking one. Let you decide which looks more appropriate for a bike named Butch(er)... PM me how to send payment please kind sir...
got some 3 month old 9 speed stuff you can have if any good. FOC
mech, cassette, shifters, chain. needs a clean tho.
Hi Ton... trying to stick with 1x but your proposition sounds ace. What is it please (Deore ?)
Hi Shaf, they are indeed worn, XT most so at the top
More recent SLX bottom right have the same silly bolt pattern. I have a brand new unused 34/24 pair of slx rings for those (+£15 no bolts included)
Older SLX on the left has a round pattern and may have had a file taken to the edges of the chainring 'arms'
£22 quid a set, in the post. No BB, No Chainrings (I will remove any attached), NOT Boost.
Packaging will be haphazardly cobbled together from bits of card.
£15 a set collected in Glossop, delivered / left in a garden in Burnley on Friday night, or hidden behind that wall Shaf, you know... where you hid the crown race
Mythste, Same price, same deal for whichever Shaf doesn't want. Maybe PM me to free up Shaf's thread
I will take the old silver slx and that xt at the top please Dave. I'm gonna assume they'll take 1x easy enough...
I'll have em delivered to 'The Wall please Dave. Tell me when
remind me your paypal and I shall forward the £30 across shortly...
Cool. I'll PM you the payment and make a plan to deliver to the wall
1x is all I ever used them for yes.
Tony... I'm all sorted for (part of) the drivetrain afterall so gonna give the 9 speed a miss. Probably stick with 1x11 (unless absolute black have any rings that a 12s compatible to go on the older cranks I've just grabbed off Dave...
Re: Wtd: 31.8 seatpost
Threas title changed. 31.8 seatpost. Something a bit special but not stiff and painful (for me it's always been) like a Thomson. Ritchey WCS would be ideal...
What length seatpost do you need?
At least 350 I'd say. Might even be 400... What length have you got please Sam and what is it pls
Shafiq, the Ramin takes a 27.2 post if you can get or still have the shim for it, and *I think* it's 30.9mm w/o a shim not 31.8mm. Can check a drawing later today if that helps.
Oh... erm... really. Let me check it out again. Pretty certain my calipers measured up at 31.8mm on the post that's already in there...
Re: Wtd: xtr rear mech/shifter 11spd
Xtr 11 sped has been added to the wants list. Otherwise I'll just have to buy an XT off CRC some time soon.
Anyone?? Need it to be a looked after one without lots of mud stuck inside and all over
Yup... defineilty not a 27.2... I just rechecked and removed the post. Its actually 31.6 I needs... Looks like Evans might have done a Planet X on you
Just checked the CAD file and it is 31.6. My ropey memory, not Evans doing anything wrongredefined_cycles wrote: ↑Thu Jan 28, 2021 4:49 pmYup... defineilty not a 27.2... I just rechecked and removed the post. Its actually 31.6 I needs... Looks like Evans might have done a Planet X on you![]()
31.6 to 27.2 shim and a 27.2 post (with a good seat clamp as it can be more slippage-prone with a shim) will be the comfiest
True... but it'll not do the name Butcher any good (with a fat seattube that joins into this puny looking seatpost
