XTR front derailleur and double/triple shifter, came off a 10 speed set up. I’m not too clued up on the mounting types but it has two bolts to mount to side facing tapped holes in the frame. I have a spacer/adapter from the Canyon frame it came off which I can include. £50 posted.
XTR rear mech, 10 speed long cage. Jockey wheels were kaput so I’ve taken them off, will need new ones. SOLD.
All above is used so shows usual signs of this.
Crank Bro’s Iodine 2 bars. Light use. 700mm and uncut. 30mm riser, 6 deg back/5 deg up. £20 posted.
Happy to send pictures. Can reduce price for postage on multiple items...
XTR kit and some bars
Re: XTR kit and some bars
PM'd you about the rear mech...
Rear mech sold.
