Wtd: road/CX Shimano hollowtech cranks or R side only
Preferably black. Lower teeth rings are better. 172.5mm if its only thw drive side you have available. Nothing less than 105 or equivalent please (sorry).
Cheaper is better please and teeth need to be goo useable. 10 speed or 11 is fine...
- Escape Goat
Re: Wtd: road/CX Shimano hollowtech cranks or R side only
How many holes shaf...
Ta Al... Was hoping I'd find summat with the chainrings (maybe the title should be edited). What you got and I'll take a look at how much rings is gonna cost me... Please, ta... how much aswell (for what you have). As a general rule, newer is better in which case (I think) 4 holes
- Escape Goat
sorry mate, thought I had a spare set of Ultegras :(
No worries. Ultegras would have been amazing and much higher than what I was expecting
I've some 175mm cx50 cranks with 36-46 rings if they're any interest? I think they're 105 level?
So sad... as 175 is probably a bit tall for me. 172.5 is max
Will PM you shortly!
Thanks Sam. Have replied. 1x no good for me unfortunately...
Still looking
i have a crank set, ultegra, 172.5mm
but the rings are worn and will need replacing
ring bolts are present
you can have for the cost of postage
Yes please kind sir. PM incoming
Just been looking at rings. Pribably not gonna be cost effective for me so won't need it. Thanks though.
