caliper bolt
caliper bolt
Discovered halfway round Today's Ride that my rear caliper bolt had fallen out and one pad gone - bit disconcerting. Sabotage by squirrel or something. Get home, check on tinternet - hens teeth Formula T1 bolts. Only one place in Italy - £25!! World's most expensive bike bolt? Rummage in shed, M3 (10p's worth), that'll do. Not sure what the insurance company'll think. Probably more than they would with a cabletie which was the other permanent option
. 2500% saving or whatever it is - bargain.
Re: caliper bolt
The Formula ones are made of cheese anyway Reg!
A tie-wrap will do the job, or even though a Hope one is a different thread size, as long as it's not over-tightened, it'll also do..
Re: caliper bolt
Thanks for tip re Hope... will investigate...
Re: caliper bolt
Is it the bolt that goes through the caliper and holds the pads in you need?
I use genuine Hope pads and the bolt comes with them so I have built a collection of spares
Re: caliper bolt
A split pin will also do - Shimano use them on some of their brakes. Nip down to your local hardware store and grab a few.
As Sean says, Hope ship a bolt (and that funny locking pin thing) with their replacement pads and it's not something that is under strain and wears out so they are usually just spares lying around in the parts bin.
Re: caliper bolt
thanks guys - will try and sort a Hope one but will drop you a line if not. Thanks!
Re: caliper bolt
If you get stuck reg I'll rummage through the stores when I'm back in on Friday and drop you a few in the post most probably be a pan head bolt mind
Re: caliper bolt
anything you put through and then bend so it cannot come out will secure the brake pads- i once used a sewing needle* and then just bent both ends upwards - worked fine- I forgot i did it and it stayed in for months
I would just use a split pin if it was £25 but not familiar with those brakes.
*it was the middle of nowhere** i was not sat at home thinking what will work
** yes yes i did lose it changing the pads
Re: caliper bolt
Reg - it's worth getting a spare set of Hope pads then keep the bolt "just in case". I've a small tin* with various spare bolts and similar small spare parts, valve core, etc. and the Hope pin is one of those.
*actually one for each bike as each has some specific bolts and it means I've always got the right one.
Re: caliper bolt
Mine are held in with a bit of old spoke since I lost the bolt
Re: caliper bolt
Thanks for all the comments gents - what a lovely Place this is
