On One Midge flared drop bars
Good condition, with just a few scrapes/scuffs
From the On One site (think these are the same, except the stem clamp diameter is 25.4mm):
"Geometry: width at the ends - 554mm - centre/centre. Width of flat section or tops - 375mm Overall drop - 112mm centre/centre. Sweep forward - 64.5mm centre/centre (from centre of bar clamp to centre of tube at the front. Flare at ends - 113deg. Finish - black anodised with lazer logos. ID at ends (for bar end shifter users) - 19.8mm. Brake Lever clamp size on main bit of bar - 23.8 (road lever clamp standard). Stem Bar C. Material: 6061 aluminium."
Can leave the scrappy tape on if you want to double wrap.
£15 + post
Tiagra 9 speed double STI levers
Good condition, with just a few light scrapes and scuffs. Fully working
Includes 4 degree reach adjusters
Will include old cables with Shimano inline adjusters if of any use
£40 + post
Midges and Tiagra levers together £50 + post
Pinnacle 440mm short drop bars
From a Pinnacle Arkose
6061 aluminium
440mm width
125mm drop
70mm reach
Very slight flare
31.8mm stem clamp
Good condition - tape marks the only sign of use
£10 + post
Sora 9 speed double/triple STI levers
2x9 or 3x9. Good working order. The usual scrapes and scuffs but no major damage
£25 + post
More photos of everything here: https://imgur.com/a/IcMQHyn
