"Wyld Stallyns"...very subtle
Having floppy issues & erection problems getting your pole up?
An all too common scenario for me - you scope out a spot on the map, check out the aerials, add some nous and think "that looks like it will be OK" Then you get there, it's dark and your chosen bit of woodland has been a) clear felled, b) surrounded by a bog c) got bleutered by a wind storm, or c) is a swamp.... In this case it was just a case of lots of damp bracken between me and the trees and a lot of windblow. Plus I'm quite picky these days, having pitched up in some fairly marginal spots. In this case it all turned out well!Tractionman wrote: ↑Sat Nov 11, 2023 11:25 pm lovely pics @fatbikephil, curious what it was about, 'in the dark it all looked a bit iffy', that put you off the spot?
Thanks for your reply @fatbikephil -- I have yet to venture out on an autumnal bivvy, I am waiting for the 'right' conditionsfatbikephil wrote: ↑Sat Nov 11, 2023 11:45 pmAn all too common scenario for me - you scope out a spot on the map, check out the aerials, add some nous and think "that looks like it will be OK" Then you get there, it's dark and your chosen bit of woodland has been a) clear felled, b) surrounded by a bog c) got bleutered by a wind storm, or c) is a swamp.... In this case it was just a case of lots of damp bracken between me and the trees and a lot of windblow. Plus I'm quite picky these days, having pitched up in some fairly marginal spots. In this case it all turned out well!Tractionman wrote: ↑Sat Nov 11, 2023 11:25 pm lovely pics @fatbikephil, curious what it was about, 'in the dark it all looked a bit iffy', that put you off the spot?
Last November it was lashing rain... To be honest I generally sleep pretty well on my bivvies. The whisky helped no doubt!
Phil wrote: Plus I'm quite picky these days
The general rule of thumb for underquilts is to use one that's rated about 5C lower than your expected temperature use, i.e. one rated at 0C is probably good to 5C and so on. Does depend on how windy things are - a wind sock can help in those situations but only by a couple of degrees.
