Bargain Alert Thread
- Dave Barter
Re: Bargain Alert Thread
Thanks all I've managed to sort it ;-)
Phew!!!Dave Barter wrote: ↑Thu Mar 14, 2024 6:02 pm I’ve not bought it yet!
edit: can't use the STW link as I'm not a paying member
edit: can any paying member see the discount code applied ;-)
It's open to any subscriber, so free trial or one month's digital only for 99p or whatever should do it!
- Dave Barter
;-)johnnystorm wrote: ↑Thu Mar 14, 2024 7:15 pmPhew!!!Dave Barter wrote: ↑Thu Mar 14, 2024 6:02 pm I’ve not bought it yet!
edit: can any paying member see the discount code applied ;-)![]()
Interesting because the crossbar stiffens it makes it less comfy while also being too thin for mounting things to? : ) I suppose it'd be useful for stabilising a bar bag strap. And £15 is a good price.
I can't decide quite how that bar is meant to be orientated - looks more like a motocross bar
Too late for you now. But TREDZ now have em at £340 plus 10% using the discount code up above. They weren't that cheap so your post might wel have caused the occurrence...
https://www.tredz.co.uk/.Garmin-Edge-54 ... 85ca93ad40
Think that's the bar they use in their Compact Neo ebikevoodoo_simon wrote: ↑Thu Mar 14, 2024 10:59 pm Interesting bar from Cannondale
https://www.merlincycles.com/cannondale ... 04238.html
https://www.cannondale.com/en-gb/bikes/ ... ompact-neo
I've got a similarly interesting Stooge Junker bar. It's in a box in the shed for the reasons listed
... and there I was thinking it was a loop type bar designed to be laid 'flat'. Guess I was right about the motocross thing thenThink that's the bar they use in their Compact Neo ebike
DJ bar? Too narrow for me, if you are going to go for the full vintage scrambles bar , it needs to be at least 850mm wide a la Surly sunrise....voodoo_simon wrote: ↑Thu Mar 14, 2024 10:59 pm Interesting bar from Cannondale
And Start fitness as well, all keeping an eye on each other...redefined_cycles wrote: ↑Fri Mar 15, 2024 10:04 amToo late for you now. But TREDZ now have em at £340 plus 10% using the discount code up above. They weren't that cheap so your post might wel have caused the occurrence...
https://startfitness.co.uk/products/gar ... uter-black
Code is FORDYRUNS
- Dave Barter
I did say that would happen
Mine was £339 but I have to look at STW for a month
Discount code wouldn't work for that Dave. So you still saved 99p (and the insult of having to sub at STWDave Barter wrote: ↑Sat Mar 16, 2024 6:08 pm I did say that would happenMine was £339 but I have to look at STW for a month
I've had a sub at STW for years. It's the best of the magazines and a really useful forum - good folk there, and associated with them, too. They try to do things right in a really challenging niche. There are some plonkers on the forum, multiplied due to numbers using it. Everywhere has a proportion.insult of having to sub at STWsorry)
- Dave Barter
I’ve had personal experience of the owners. Best left at that
Was swearing involved in your interaction
- Dave Barter
Fair enough, but just thought I'd add some balance. I've met Mark and Chipps and they were at neither end of the knobhead>>legend continuum.Dave Barter wrote: ↑Sun Mar 17, 2024 6:07 pm I’ve had personal experience of the owners. Best left at that
In my experience one comes across as disengaged and the other definitely occupies one end of that spectrum, he's probably offered to fight as seems his styleFair enough, but just thought I'd add some balance. I've met Mark and Chipps and they were at neither end of the knobhead>>legend continuum.
- Charliecres
Cheap Garmins on Sportpursuit - Edge Explore, Etrex Touch and lots of watches
They've got Maxxis DHR tyres too - 27.5x2.8 and 29ersCharliecres wrote: ↑Sun Mar 24, 2024 10:31 am Cheap Garmins on Sportpursuit - Edge Explore, Etrex Touch and lots of watches
https://www.sportpursuit.com/catalog/pr ... id/3445281
- Bearlegged
Sea to Summit quilts and bags with muchos dineros off
https://seatosummit.co.uk/collections/outlet-clearance
