Completely agree Bob and BTW, I've no axe to grind - I did have an Exposure branded SP fail. Exposure themselves were of no use but SP were superb and sorted me out quickly and went well beyond what I might have expected of them.
My point (inc' wink) was that it would appear that buying a dynamo is a little bit of a lottery. There's people like me that have had them fail quickly and others that have run exactly the same unit for 1000's of care free miles - I simply wouldn't bank on buying one and believing that you'll still have the same unit in 2 years time.
Best/modt economical/robust dynamo hub
Re: Best/modt economical/robust dynamo hub
- ZeroDarkBivi
If you need to generate 20,000mAH per day- best of luck! Unless you are an expres train, I wouldn't bet on generating more than 10% of that per day, and that's before you go off-road.redefined_cycles wrote:I do have my powerbank which is 20000mah but it'll probably only last me around a day and a bit worth of charging (front and rear lights/phone/garmin).
Recently got 50hrs out of a set of lithium AAs in the Etrex, using OSM mapping downloaded free from the net. 30g for a pair.
I bought an XT hub dynamo as it was:
£65 from Germany
Serviceable and repairable by a home mechanic with out wheel rebuild
Generates more power at low speeds than any other dyanamo
I attached it to a 29+ wheel and while i was thoroughly dissapointed with the light generation i was content with the GPS charging capability off road. It kept my device (old android phone with mmtracker) fully charged and on a road section it topped up my phone too.
i found a German article that was up to date and showed efficiency and power output bench tested:
http://www.nabendynamo.de/service/pdf/ar_09-10_2014.pdf
Got my mum to translate if your interested?
It convinced me that the XT was an excellent option so i paired it with this:
http://www.ebay.co.uk/itm/VeloCharger-H ... 2534754636
this provides upto 1500mAh where many other brands are limited to much less
£65 from Germany
Thanks buddy... I am interested in yhw translation please...duncdan wrote:I bought an XT hub dynamo as it was:
£65 from Germany
Had two sp dynamos and both have had bearings fail after a very short time of use. One never lasted more than 300 miles.
One stopped completely and would not turn the other developed side play.
https://flic.kr/p/KR3GXR
https://flic.kr/p/KCyr4i
You can hear the side play in this vid
Now own a SON 28 qr for the MTB and no problems so far, now also bought another to go on the Alpkit bike that I intend to get soon.
Use it with a sinewave revolution on iPhone 5s, with viewranger app as gps/mapping. Works really well.
Thanks so much. Yes it did work and I now feel like a hub dynamo pro (in comparison to my knowlwdge previously)...
Im glad you posted as i had planned to post it 6 months ago as i thought someone would find it useful! Good luck with the build.redefined_cycles wrote:duncdan wrote:Hope this works.....
