Hammocks.
Taylor
Re: Hammocks.
Post by Taylor »
I used to use a mat when I got my first hammock which was fine but when I got my first underquilt I vowed never to use a pad again. It's just so much more comfy and theres no fear of the mat popping out from you in the middle of the night.
valleydaddy
Re: Hammocks.
Post by valleydaddy »
yes a hammock trip could be fun :D
would a hammock event be better for the winter bivvy - getting off the ground etc?
I think I will try one and these for £10 are a cheap way to try it out so will order one now :D
If I do like it, yes Flatfish I maybe up for a lend of an underquilt ;)
Re: Hammocks.
Just remember Pete, the ten quid ones don't have any midge netting ... but hey, you can't go wrong for a tenner ;)
valleydaddy
Re: Hammocks.
that's a point Stu so is there another one with the netting you/Nevis/flatfish can recommend might as well get the the right one from the start ;)
what are the ones with a pocket underneath etc???
Re: Hammocks.
Right Pete, the ones with the 3 layer bottoms are the Green Hornet which only seem to be left in odd colours. The other option would be just the Jungle hammock which doesn't seem to be 3 layers although it does have a full net or the one below which has some bottom insulation built in and a full net.
http://www.ebay.co.uk/itm/Insulated-Cam ... 5645270962
If you don't mind the Rasta look then the Tropical Green Hornet looks like the one, also avaliable in a rather smashing orange :D
Re: Hammocks.
flatfishy have you bought the last of the green hammocks then?
Re: Hammocks.
Very long toes pictured on that ebay page :shock:
Taylor
Re: Hammocks.
Post by Taylor »
Nope, I got blue I think. Nothing fancy, just the el cheapo tenner version. No bug net.
Taylor
Re: Hammocks.
Post by Taylor »
That camo one looks ideal as a first hammock with built in insulation!
Re: Hammocks.
Yea I thought the camo one looked well considering the price ... the insulation must be some benefit.
valleydaddy
Re: Hammocks.
what about weight though is a hammock set up heavier???
now that I am a weight weeny ;)
Taylor
Re: Hammocks.
Post by Taylor »
Hammocking is generally heavier but the comfort benefits, for me, are worth the extra half kilo.
valleydaddy
Re: Hammocks.
ok so if i order one of these will that cover the mozzy and under blanket issue in one hit??
http://www.ebay.co.uk/itm/Insulated-Cam ... 098wt_1139
all this time off is going to cost me :shock:
Taylor
Re: Hammocks.
Post by Taylor »
Yup.
All you'll need is a decent size tarp to cover you.
valleydaddy
Re: Hammocks.
will my Alpkit rig7 be big enough???
Taylor
Re: Hammocks.
Post by Taylor »
If you set it up corner to opposite corner to get the longest ridge line I reckon it should be big enough.
valleydaddy
Re: Hammocks.
thought so they are a good size, ok think I may order one :o
I wish I had some trees in the garden to try it out :(
Stevemorg
Re: Hammocks.
Post by Stevemorg »
Pete - are you really sure you want to try and climb into a hammock in your current state?
valleydaddy
Re: Hammocks.
no of course not Steve ;)
But I have just had a bivvy ninja coloured black cast fitted today 8-)
but I have ordered a insulated camo to try out
Taylor
Re: Hammocks.
Post by Taylor »
Best hope the sun doesn't come back for summer or that cast is going to be honkin' by the time it comes off. :shock:
valleydaddy
Re: Hammocks.
don't worry hoping to have surgery in next 3 weeks so won't on too long fella ;)
valleydaddy
Re: Hammocks.
black cast by valley daddy, on Flickr
Taylor
Re: Hammocks.
Post by Taylor »
Matches the car I suppose ;)
Re: Hammocks.
Jesus, it looks like something from a St Trinians film ;)
valleydaddy
Re: Hammocks.
you should have seen what else I was wearing Stu.
This thread is getting away from hammocks nicely isn't it??
so I have ordered a camo insulated hammock now need tips on how to tie/get in the chuffing things without busting my other leg or arm for that matter please ;)
