Only issue is how you anchor the front flap/hook by your toes. A loop of elastic might do it. I'm still tempted by the camo yeti gaiters I linked to above. If your shoes are stiff enough that would solve that problem.composite wrote:You could still get these on with over shoes as well right?
Gaiters
Re: Gaiters
Re: Gaiters
I should say one or two things about the fit (in case anyone is interested). As they're designed for walking boots, there's lots of room around top of the cycling shoe. I've cinched the rather neat internal adjustment straps up so they fit ok and don't flap, but there is a bit of room left. This would allow space for overshoes too, but as Johnny says, you need to hold down the front clip somehow.
The ones I bought are size small, so the volume was a better fit around my size 7 Shimano boots.
