The weakest part of any sectioned pole will always be the spigot where the sections join. On a well designed pole used correctly, it doesn’t cause a problem. Poles are very strong when subjected to compression forces but what about those stresses applied when subjected to bending forces which might occur if the pole is set at an angle?
Shock-cord – it’s there for a reason.
Increasing the wall thickness of the spigot is the obvious safeguard but by how much? A solid joining spigot would be the perfect solution but most poles have an elastic cord running through their centre to hold the sections together. Simply removing the cord and having loose sections is one answer but using a pole made from unconnected sections can prove frustrating … especially if you’re not blessed with dexterity and patience.
Is there a way of incorporating solid spigots into a pole and still being able to securely hold the individual sections together? There is now.
Aluminium, steel, carbon and titanium. There are a number of materials used to make handlebars and now you can add grass to that list. The ‘Gump’ bars from Passchier are made from bamboo and we all know that bamboo is a member of the grass family and not wood as some people believe – don’t […]
Whether you think ‘Gravel’ is (a) the new cycling religion, (b) an exercise in good marketing or (c) simply a way of making roadies feel better about themselves, matters not because no one can deny that gravel is now at the forefront of cycling and appears more popular today than it was last week … […]
Despite my best efforts, I’m sat here writing this surrounded by the intoxicating aroma of bacon butties. Why do I smell of grilled pork products? Because yesterday was the second edition of the 2021 BB200 / 300 and it’s my job to feed all those returning. Each October since 2011, a group of riders have […]
Strictly Necessary Cookie should be enabled at all times so that we can save your preferences for cookie settings.
If you disable this cookie, we will not be able to save your preferences. This means that every time you visit this website you will need to enable or disable cookies again.
